IF YOU HAVE THE MANUAL ON THE A2100 CONTROL IT WILL WALK YOU THROUGH WHAT CINCINATTI CALLS A DRIVE INHIBIT. YOU CAN DO MOST OF THIS DIRECTLY ON THE PENDANT ITSELF UNDER THE SETUP KEY. FROM THERE YOU GO TO INHIBIT AN AXIS IT WILL DISPLAY ALL CURRENT AXIS IN USE. PRESS THE 4TH AXIS INHIBIT AND IF YOU INTEND TO USE THIS AXIS IN THE FUTURE YOU MAY WANT TO PRESS THE REMEMBER AXIS. YOU THEN GO INTO THE CONTROL AND TURN THE 4TH AXIS DISPLAY OF. IF THE 4TH AXIS WAS TAKEN OFF RIGHT BEFORE SHIPPING TO YOU THEN THERE ARE SOME JUMPERS THAT MUST BE PLACED IN THE WIRING TO THE BDS4 FOR THE DRIVE THE MANUAL WILL WALK YOU THROUGH THIS. IF YOU HAVE NO MANUALS A WOULD SUGGEST CALLING GBI MAINTENANCE TECHNOLOGIES AND ASK FOR MARK NICHOLS AS HE CAN EMAIL YOU THE PROCEDURES FOR ALL THIS. |
