Originally Posted by Greolt You might want to consider letting the DSP take the feed rates from the gcode.
There is a setting on the DSP, I forget what it is but easy to find, to use the feed rates as contained in the gcode.
That way you can have suitable feed rates set up in Vcarve Pro for each tool and they will be output with the gcode.
Greg |
Yes, that's convenient to set the working speed automantically. the path is:
MENU---AUTO PRO SETUP---G CODE READ SETUP----READ F , Change is to ENABLE will be ok
