You might want to consider letting the DSP take the feed rates from the gcode.
There is a setting on the DSP, I forget what it is but easy to find, to use the feed rates as contained in the gcode.
That way you can have suitable feed rates set up in Vcarve Pro for each tool and they will be output with the gcode.
Greg |
