Thread: Shaft lube
Old 06-10-2003, 03:18 PM
Zephrant Zephrant is offline
Zephrant is on a distinguished road
Shaft lube
For the people using hardened steel shaft and Rulon or other synthetic bearings, do you use any lubrication on the shaft for rust protection? The synthetic bearings don't need the lube for running, but I'm concerned that my shafts will rust up when they sit in the basement.
I don't want to use an oil based lube, because I'm afraid it will collect dust and chips from MDF and acrylic.
How do you keep your shafts from rusting?
Zeph
