Originally Posted by OCNC Would it work equally well to use shielded cable with a dedicated ground wire as well as a grounded shield drain wire?
Thanks again!
Chris |
Yes, probably even a little better, simply use the adjacent gnd pin. All the even pins are wired to ground.
Phil
