Old 12-03-2008, 01:27 PM
Geof Geof is online now
Turn the eccentric bushing clockwise when adjusting it. This way as the bolt is tightened it holds it in place; if you have turned the bushing counterclockwise it tends to loosen a bit when the bolt is tightened.
