This might be a dumb question...
How do you use/design/install eccentric bushings like those found here:
http://www.cadcamcadcam.com/eccentri...ovewheel2.aspx
Is it basically a matter of hold the bushing with a wrench in the position you want and then through bolt the bearing or something more technical than that?
In general, I'd like to know a lot more about placing/using these types of bushings.
Thanks!
