Old 12-03-2008, 05:31 AM
TWyatt9 TWyatt9 is offline
TWyatt9 is on a distinguished road
Phix I have a LX-1 control the switch I'm talking about is the disconnect switch where the main power comes in to the machine. Everything is turning the proper direction so I'm assuming the Phase is correct. The hydraulics come up and build pressure with no problem. For clarification The lines come in from the breaker box and go into the top of the disconnect to turn the hydraulics on. The wires are marked Red on the left White in the Middle and Blue on the Left and green fof the ground. I don't have the machine wired to a ground rod. But it is grounded through the breaker panel. It just doesn't sound right kind of sounds like it is trying to single Phase. My shop power has two 120v legs and one 220v leg i have the 220v leg in the middle on the white wire. I'm not sure if the switch is a no fuse breaker. It says Tryrister on the inside. And yes if you check to ground I'm only getting 78v across the blue and other leg i'm only getting 190v. Ihope this info makes sense. If you'd like to call me this evening my number is (727)277-3181 Tim Wyatt PPM Inc.
