Originally Posted by ger21 Most illustration programs. Illustrator, Coel, Inkscape...
But if you're using Inkscape, use the .sxf exporter I linked too. I only suggested .eps if you must export from illustrator. You'll still need to convert to .dxf, so going straight to .dxf from Inkscape is probably the easiest route. |
Seems like a good idea. I was just wondering is this possible using PHOTOSHOP?
