As you say " In essence" this is true.
You need to work out how much axis travel a stepper step will tranlate into. If the end of the travel is small enough, (acceptable tolerance) then use it.
Because most computer software can only drive at certain top speeds (PPS), it would be wrong to gear down your drive too much, because that would reduce the top speed that your axis can travel at. |
