Bar stock as close to finished size as possible. Cut to length. Drill and tap half the pieces, drill and counterbore the other half and mill the top flat. Bolt together and bore centerhole, clamp hole in lathe chuck and turn OD or use hole to clamp in mill and cut OD. Machining part, then cutting in half and surfacing joint face is a waste of time and material. |
