Why not build yourself one? Birch ply will work fine, you can even go acrylic on the lid so you can see what's happening.
I am about to do the same, if you like, I will email you the code when I get it done. I am going to put a couple of those super bright LED clip-on lights on the inside of the hood. Hardware store counter has them for about $3/ea. Figured I'd velcro them on. Also, you should get a reducer for the vac hose, so you can use a smaller wet/dry type hose which is much easier to deal with. |
