Originally Posted by w102acd Viking,
Based on the size, the trucks are HSR20LR.
w102acd |
They have the same cross sectional dimensions as the compact HSRxxR series, but are longer (in your case 16 mm longer) and thus the load rating is greater. Quite a bit actually! Good for you.Take good care of them.
The greater length also explains the higher ball count in your trucks.
