Old 11-23-2008, 03:07 PM
dertsap's Avatar
dertsap dertsap is offline
Gold Member
dertsap is on a distinguished road
Originally Posted by slammedxonair View Post
. Would I be able to build this with less than say another $200 into it? I allready have a router I can use. Thanks
the electronics is usually the bulk of the cost and you already have that .
slide cost will be minimal if you use the diy skate bearing slides and if your building an mdf machine then a chunk of mdf is $20
you can use ready rod for leadscrews which is dirt cheap until you can upgrade
the relay board is just to have the computer control you router on/off rather than having to turn the router on manually ,its only gravy and its not necessary
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
