  #12   Ban this user!
Old 11-22-2008, 03:40 PM
syil canada syil canada is offline
syil canada is on a distinguished road
syil canada
feel free to take some pictures of the "CNC board" and email them to me, i will have a look to see what the issue is.
also if you have not done so yet, check your port address in ports and pins settings. the default address is 0x378, if you have installed a parallel card the address will be different. check in the windows device manager for the parallel card address, make sure it is the same in the ports and pins settings.
keith@syil.ca
or give me a call @ 403-400-7945
i attached a photo how to disable the mach3 charge pump try this and see if you get movement.
Name:	disable charge pump.jpg‎
