I know this is a late post, but smartcam v 11.5 I don't think used a dongle, they use a software code read off your CPU.
if you have to change pcs then you call them up and they will give you the code that matchs your software.
I know there was dongles used in the dos versions back in the early nineties. I thought version 10 or 9 is when they quit using dongles.
I like the dongles much better personally that way when I went home and wanted to work I could just take the dongle with me.
version 11.5 works fine off of xp, it will lock up from time to time unless you turn off a certain perameter in windows language pack on xp.
hopefully in the real near future I am upgrading to freeform ver15+ its suppose to be awsum. |
