Ask and you shall receive | | I called 11-12-08 and spoke to an engineer and received these prices.
These prices do not include tax or shipping:
The IVTAAH rail (additional height so a belt can return on the inside of the extrusion) is $23.69 / ft.
The IVTAAG appears to be the same extrusion without the additional height. It is $19.68 / ft.
The IVTAAB rail only, for mounting on the 8020 extrusion is $17.34 /ft
The 3 above rails are rated for 1250 lb/f and have a maximum length of 12 ft.
The carriage with or without slots, with 2 fixed v-groove bearings and 2 cam v-groove bearings is $150. It is rated for 4000 Nm or (892 lb /ft)
I asked if they would sell the bushings and they are $1.50 for fixed concentric (VB2) size 2. They are $4.45 for cam excentric (VBA2) size 2.
The v-groove bearings are $15.91 each for a shielded bearing and $16.30 for a sealed bearing.
You can purchase the v-groove bearing from VXB.com for $9.98 ironically the photo they show if you enlarge it shows they are the PBC VB2 bearing.
I used the IVTAAH at work with the oversize carriage. Even under a heavy load it glides from one end of the rail to the other like a frisbee sliding on ice.
Robert |
