Old 11-17-2008, 08:14 AM
SkipW SkipW is offline
SkipW is on a distinguished road
Most welcome Dave. Glad that worked for you.
Corel trace is fairly good but you usually have to do a little tweaking with the results. Like tracing that ornament picture you posted, you would probably end up with an inner and outer line if you view the trace in simple wireframe view in Corel. If so, you would select all and ungroup the drawing and just delete the inner line, and use the Object Properties manager to make sure the line is set to Hairline for vector cutting. Then do a "Save As" and choose AI - Adobe Illustrator so you can import it into LaserCut.
I'm not sure about LaserCut 5.1 but with my LC 5.0 it likes me to save vectors as Adobe Illustrator version 7.
Happy cutting!
Skip
