Old 11-13-2008, 07:58 AM
laka laka is offline
laka is on a distinguished road
Sounds like you got it figured out.
If this is an A2100 control, it isn't necessary to put the exact size of the tool in the "Diameter" field of the tool list. If you're program is for a 1/2" endmill, and you are using a 0.480" you will still need to put -0.020" in the "Diameter Offset" field to achieve your correct size.
