The trick in "prestressing" is to add the load BEFORE you let the epoxy cure. Then when it is cured you can cut off the extra all thread, you would want to do say 6 all threads in a big tube to equalize the tension. This puts the mass under tension and yes it makes it a lot stronger. Neat trick indeed.
Evan
__________________ Evan.
"You're making WHAT?" |
