Originally Posted by Kiwi Could you get the centre from a clutch plate which suits the spline and fit this into your hub.
Hint: Take absolute minimum off splined sleeve when machining to suit hub as this may shrink when welding to the hub |
That could be an option, if i could find one such center. Tommorow I will contact the nearest wire EDM shops and consider what they advise.
