Old 11-11-2008, 01:14 PM
Brian Queen Brian Queen is offline
Brian Queen is on a distinguished road
Laser cutting paper question
Has anyone been able to laser cut paper without leaving a burnt edge? I have a Rabbit 80 watt HX1290SE and whatever combination of power and speed I use I get a burnt edge. I can get it down to minimum but it’s always there. If I stack my cut sheets (which I cut one at a time) you can really see the burnt edge and it can be messy in that the carbon gets on your fingers and contaminates the white paper.
I always turn the sheet over, printed side down, as most of the burning occurs on the top side of the sheet. After cutting I apply 2” wide painters masking tape over the whole sheet and when I peel that off it picks up most of the carbon. I’ve also noticed that the amount of burning varies with different types of paper and the thicker the paper the more burning.
Since I plan on doing a lot of laser cutting of paper for some architectural origami structures I’d like to hear how other people deal with this problem.
Brian
