problem fixed. One of the reference switch wires was hooked to the motor. This is why the old control didn't work it was only getting power to 1 set of coils. Hooked the other wire up and all is fine. make sure you don't have a loose connection or check the resistance with a multimeter to make sure you don't have a burned out motor.
Greg |
