Old 11-02-2004, 04:16 PM
squarewave squarewave is offline
squarewave is on a distinguished road
Reversing the Spindle?
Here is an easy one for you guys. My spindle is running opposite the way it should. Is there a way to reverse it in the setup? I tried using a negative 1 on the GEAR paramter for that axis, but it didn't change.
I know I can swap the SPINFORWARD and SPINREVERSE in the M code file, but I don't think that is a great idea (in case there is other logic existing or I write some in the future and I forget it is reversed).
I have a DC spindle motor and drive, so if I have to rewire it, I assume I swap the Tach leads and the main leads (that go to the brushes). What about the field winding?
