The holding torque is often stated on the motor oz-in etc, this is the maximum torque the motor is capable of and will resist any force up to this value.
If you want to know an unknown torque, you need the voltage rating of the motor and supply the motor with this constant voltage, the torque can then be measured by pulley and spring scale for e.g. and tension applied until the break-away torque occurs.
__________________ CNC, Mechatronics Integration and Machine Design.
Albert E. |
