Hi... well you have set yourself a challenge then.
The motor you describe sounds lke its a NEMA17 style case... looks the same but is small than the NEMA23 thats in the video. Unfortunately it about 10x too low in torque to be of any use for your needs.
M4 threaded rod is far too thin for a leadscrew - it will buckle under the cutting force, even on ply. Also the pitch of M4 is too fine, your cutting speed will be glacial! 8mm x 1.5mm pitch might just about do (I think thats whats in the video).
If its not a rude question, I get the impression you are rather younger than the typical member here... would I be right? |
