Thread: Need Help! Deflection Calculation
Old 11-04-2008, 10:55 PM
TOTALLYRC TOTALLYRC is offline
TOTALLYRC is on a distinguished road
Originally Posted by Freff View Post
Here is where I am so far with the build. All the parts for the Z assembly including the router (rotozip type) is 15lbs. I will try and measure any deflection on the rails tomorrow, but as it is it's very rigid.
Thanks for the replies.
I like the looks of it so far. You seem to have the Y axis rails a good distance apart which should minimise the tortional deflection caused by the forces of the z axis.
I am not sure about how you have the y rails on one side and the z axis on the other side, as the distance from the center line of the cutter will be greater than if you went with it all on one side. But at this stage, check the flex/torsional flex and see what you come up with.
Seeing how short the Y axis is and how well made the rest of it is, I think you will make out well.
Keep up the good work.
Mike
