If you put a 2" diameter spool (1" radius) on the shaft and use it as a sort of "winch" to lift weights, however many ounces you can lift is the definition of the oz/in rating. I.e., 300 oz/in is the ability to lift 300 ounces at a distance of 1" from the turning point.
Your method would also work but you need a rod of "zero" mass in order to measure accurately (well, just as you need a spool of "zero" mass) and the measurement is only accurate at the point in time where the scale forms a perfect right angle with the rod. |
