Originally Posted by bumperscoot I have yet another dumb question for the Sprutcam gods..
I have added a Roughing Waterline operation with a 3-Flute rougher as the first machining process in my project, and set the Axial/Radial "Stock" parameter to .035" to provide for a finish pass.
A Finishing Combine operation immediately follows with a 1/2" finish tool, with the "Stock" parameter set to 0".
After reviewing the simulation, the roughing operation continues to the part Z finish height of -.125" (after 3 passes), and does not provide stock for the finish pass. The Finish Combine pass toolpath also stops at a Z height of -.125", essentially making nice swirlies on the part face without cutting..
Both operations have the same faces, etc..
I've tried several combinations of roughing/finish operations, all with the same result.
Can anyone explain how to create a separate finish pass?
Many thanks..
Steve |
Steve, you might want to check on the sprutcam forum to ask this question.
