Originally Posted by c5chris99 Newbie Here,
Long time reader, first time post. We have a Mazak Quick Turn with a mazatrol t1. we just recently aquired this unit and have two problems any help would be greatly appreciated.
The first problem is when trying to home the z axis. When moving towards the home switch the z axis shutters then throws a stop. The error is #2 excess z. Spoke with Mazak and Mitsubishi and both are kind of stumped. I have cleaned the brushes, and have adjusted the gain and dether. Helped some but still shutter and stops. It seems to happen any time you contact the home switch. I am starting to think it might be a encoder or a resolver. If anyone has any light on this situation i would greatly appreciate.
The other error which will not clear is 61 NHEAD Lube. I have checked the spindle lub and all is fine. I thought it might be a bad presure switch but cant seem to find one near spindle. Mazak cant seem to find any answer. Anybody experience this before?
Thanks in advance for anyhelp! |
The failure of the Z axis, you can correct it by lowering the speed axis for approximation of the RF parameter and lubrication likely to increase the value of SQ, 512 works in insurance.
Sorry my English is the translation of Google
Best regards
