Old 10-31-2008, 03:51 PM
ClaudioG ClaudioG is offline
ClaudioG is on a distinguished road
Very nice work there Rod.
What size and type of bit were you using for the inner circle and outside cut at 780mm / min at 0.5mm per pass.
I noticed you switched to a 3mm end mill for the slot at 400mm / min at 0.3mm per pass.
And what software are you using to drive the machine. It has a nice fluid motion.
Cheers,
Claudio
- WidgitMaster Wide Router with Kress FME 800, HobbyCNC 305oz Stepper Kit
- WidgitMaster Midi Router with Dremel
