I have a chinese machine that was built in the Guangdaly factory but to an Australian design, it was supplied with NCStudio & TypeEdit, I haven't had any problems with NCStudio running the machine accurately & consistantly but have given up on using TypeEdit (no documantation or support, too frustrating for me).
I too am using a Fanuc16m/0m post pro & have had no problems at all with running the code through NCStudio, I have not needed to remove any lines of code or modify any code to make it run.
From memory, when i was cutting TypeEdit generated code, it was output as *.U?? the question marks after the U denote the toolpath number & * denotes the file name. It also used a Machison.dll in the machine setup.
If I can be of anymore help just ask
Rob |
