Old 10-30-2008, 03:31 PM
zanellan zanellan is offline
zanellan is on a distinguished road
Off the top of my head (so bear with me!), you have to go into MDI mode and press the AUX GRAPH button until a page appears with the options of tool library. Press that and it will display what tool pot number is holding what tool. EG...POT NUMBER 6 COULD BE HOLDING TOOL 2. It will also tell you what tool number the spindle is holding. You then have to tool change in MDI(ie swap then all around until the pot number corresponds with the tool number. Finally when the last tool is in the spindle simply put in an M33 code and it will automatically send it to the right pot number). If you don't understand this i can go through it in greater detail with you when i have more time! Good luck!
