Kreutz,
thanks for the suggestions, I'll check all of the 7805's, I've got spares from other manufacturers that I can change out. I'm getting much better at changing components on a PCB. I've checked the USB power coming out of the computer and it's only 4.97. tomorrow I'll pull the cables out of the USB card I installed a while back and see if the power level goes up. either way it looks as I need to do something about the my 5vdc sources . I've currently got quite a load on the USB board and probably need to use the 5vdc available from the PC power supply I've installed in the cabinet and move more of the load to it. I'll also check it's voltage before and after...... I sure don't need a brown out condition occurring while running a program ! As to the 4th led, none of the drives show any indication of it lighting............... I hate to see you divert anymore of your limited time to writing a check out list. between the problems H.O., Irfan and myself have had or are having, We,re developing quite a check list on the fly............. Please get me those P&P fingers, the earlier I get them the sooner you'll have spares plus you'll be able to design other styles as needed and I can get them started !
Paul |
