Old 06-09-2003, 03:52 AM
Scrit Scrit is offline
Scrit is on a distinguished road
Each of the router spindles has a 4in brush "skirt" around it, which I replaced this morning - made a bit of a difference, but not as much as I'd hoped for. There is a 120mm flexible hose take-off on each head and there are 2 x 120mm take-offs at the back of the drilling "crown". Drilling operations seem to leave waste materials everywhere, the DX is almost useless on them.
ger21
Thanks for the suggestion about air blowing. I have toed with the idea, but what I find a bit daunting is threading the extra air line and control line through the power/services chains to the gantry front. I use an air jet on our pin router when I'm copy routing plastics, so I guess it should work quite well. On the pin router it reduces the tndency of plastic swarf to weld-back.
Has anyone tried a compressed air vortex accellerator to increase waste pick-up? Seen them on welding extractors and wondered if they would be useable on larger/heavier chips.
Also are brush skirts better or worse than the polyurethane "finger" skirts I've seen on some machines?
Scrit
from the Sunny Pennines, England's Backbone
