4. Not necessarily. Some drives can be configured only for a limited range of motors from the same manufacturer. Others can be configured to any motor as long as you have enough data on the motors, and they match.
Only bid on an AC BLDC motor and controller after you have found the user manual, read it, understood it, and have determined they are suitable for you.
Some drives are special purpose and not suitable for what you need. In some cases the same drive comes in different flavours (block controller, electronic gear, electronic cam, speed controller, ....) It's a jungle, be sure you have a machete and know how to use it. |
