I am looking through the programming manual and I cannot seem to find the page listed on the control that controls ACC/DEC.
We are supposed to have the high speed die/mold package, but I really do not know exactly what thats supposed to do. ACC/DEC is on by default G45 and I can turn it off with G46, but Off is too drastic. It bangs to hard at higher rates
The manual states options like G54.1 for Roughing profile, and G54.01 -G54.03 for Programmable settings. These do not seem to work, (unrecognized g-code) so it must be yet another "paid for" option.
I rough with
Dijet SKS High feed roughers at around 220IPM with .04-.06 DOC depending on the type of steel, for CRS 220ipm is normal, for Zinc or Aluminum I approach 400ipm. With the A2100 on an Arrow2000 it is stopping or slowing down way to much in the corners, A 45 minute roughing program takes 2+ hours to complete. The same program on our Takumi with a Fanuc 18m control using HPCC (G5P1000 command) is takes just under an hour to complete. It does not stop so much in the corners.
It was not always this way, the last time we had a HDD failure I think something did not get turned back on or setup correctly, but sadly the company the did the replacement is no longer around. I hope to adjust/fix this myself and a call to MAG or whoever is serviceing these now would probably be expensive
