Old 10-29-2004, 01:08 PM
Al_The_Man's Avatar
Al_The_Man Al_The_Man is online now
Originally Posted by GalaticDan
Hi all,
1). Most of the drives on EBay I can't seem to find info. on, even at the mfg. homepage?
2). Whats the difference between an AC Servo Drive Amplifier and AC Servo Drive Controller??
3). All I want is step/dir. control and most of these things seem like weighty beasts with simple push button controls but no i/p for step/dir.?
4). Can I mix and match motor with drive/amp? (So long as I match voltage and current requirements...)
5). Any out standing AC drive control products which I should be looking out 4?
1/ you might be better to research Manuf. that offer non-dedicated systems, i.e. various makes of motors can be used with their drives. For eg A-M-C and Copley Controls and Aerotech.
2/ AC Servo Drive & Amplifier usually indicate the same thing
3/ See 1/
There are many types of AC servo drives, if you want step & direction I believe you want the PWM type, these work with digital controllers and use a TTL input for PWM & step and direction.
There are usually many of the above makes come up on eBay regularly.
Al
