New SC125MS Stepper Motor Controller!
- Full, half, 1/4, or 1/8 step microstepping
- Up to 2.5A, 30V, for bipolar motors
- Step + Direction inputs compatible with most CNC software
- Select current level with DIP switches or using resistor
- Power on and motor enabled indicator LEDs
- $74.99 Includes cooling fan and ALUMINUM enclosure ($59.99 for board only)
- Connect up to 4 axes to 1 parallel port with $4.99 adapter cable
- Integrated heat sink
- 2.1 mm x 5.5 mm and screw terminal power inputs
- Can be driven by PC or any TTL-level device -- PLC, uController, etc.
- Optoisolated Inputs for Step, Direction, Enable, Microstep Level (2 inputs, 4 levels), Logic GND -- through IDC connector or screw terminal blocks
Full information on the SC125MS is available at
http://www.salemcontrols.com/products/sc125ms.html
