Ken,
For a "wedge" draw your 6 end points, then connect your points with lines. Then use the "surface 4 sides" to surface the top, bottom, and back sides. Then use "surface 3 sides" to do the sides. Then use "merge" to combine all the surfaces into a solid. If you need a solid.
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management)
