Old 10-28-2004, 01:45 PM
Rekd's Avatar
Rekd Rekd is offline
Rekd is on a distinguished road
I meant for you to copy those functions from YOUR post and put them here for me to see it so I can try to find where your problem is.
Sorry for the confusion.
For the G02 G03 problem, I would guess your post is forcing the output of null values.
Look for this
Code:
parc            #Select the arc output
      if arcoutput = zero,
        #Arc output for IJK
        if plane = zero, *i, *j, k
        if plane = one, i, *j, *k
        if plane = two, *i, j, *k
      else,
        #Arc output for R
        if abs(sweep)<=180 | arcoutput=one, result = nwadrs(srad, arcrad)
        else, result = nwadrs(srminus, arcrad)
        *arcrad
and change this:
Code:
to this:
Code:
        if plane = zero, i, j, k
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
