The link I posted was the closest thing to what I'm looking for that I could find an image of. I'm not looking for a valve that will let out a constant stream of air like whats pictured in Johns setup or a gate valve but rather I'm looking for a valve that is controlled by how much I squeeze. Like the blowers found in my link I want this type of valve but instead of the blower tip, a few feet of hose would attach and then connect to the loc line.
I want to have the loc line setup and positioned on my mill. Then I want to be able to blow air through it as needed. The idea is that when chips build up I can just give the valve a squeeze and increase the air flow as needed to remove the chips. Does this item exist? |
