Thread: G54 or E1?
Old 10-23-2008, 12:52 PM
carbidecraters's Avatar
carbidecraters carbidecraters is offline
carbidecraters is on a distinguished road
We use E codes so they are easy to spot on a program. Since we are using -4 controls (88hs) editing a G numbered code can be tiresome for a novice operator if they type in g; and then the control just removes the first g code and then if you type in g54 it will take the place of the next g code in the line. Its a quirky thing trying to explain to guys what exactly you have to do to get the right code on the screen
We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
