There are several ways to do this but I think the simplest would be to save your existing program as a subroutine and then call it up after changing the "start" position. Your "start" position, or Y offset, can be changed in your program several ways also. You can use G10 to input the offsets, you can use G52 to shift the offsets or you can set the 5 positions with G54-G59 and call a new offset before running the subroutine. You didn't say what machine or control you are using so check your manuals for the proper way to use the G-codes and subroutines. |
