Thread: Plastic Nuts
Old 06-08-2003, 06:56 PM
balsaman's Avatar
balsaman balsaman is offline
balsaman is on a distinguished road
HuFlungDung,
The delrin nuts work great for wood routers. No backlash and stiff enough to cut wood.
For cutting steel, you are correct, there is some spring in the plastic.
I use home made delrin nuts on my router and can cut wood and aluminum no problem. There is much more flex in the wooden machine than in the nut.
I have access to pure teflon at work but it's 1/8" thick. One could compress some layers between two pieces of aluminum and tap it. Teflon is softer than delrin.
I don't think the friction is a big deal. I would stay with what ever you can find handy.
Eric
I wish it wouldn't crash.
