Old 10-18-2008, 07:56 PM
SHADOW042 SHADOW042 is offline
SHADOW042 is on a distinguished road
Smile
Ok so ive recieved my cargo
I say this about the box
It was one of the best packs ive ever seen
Nothing was moving in there and nothing was loose
Ok so ive unpacked it and started to test and check everything
I checked all the xtras first exhuast air and water pump and all worked fine
The only scary thing was the power board for the chinese plugs as this is a scary sight as it is very open and i wouldnt want to spill any water (ill change this as fast as i can)
Next up was the laser and that was not what i expected as i thought it would have been connected already but it wasnt so out came the soldering iron (i have some experience with soldering) and the fun begins
This was a pain in the rear as im trying to solder copper wire to steel and that not easy, they say rap copper wire around the steel pin tightly and then solder then join ur wire and man was this fiddly, but Ive got it done and it was only 2 wires to connect
Just a side note the machine and all the wiring was very professionally done and you can easy tell what belongs to what and its very very neat
So now i have everything connected
I started to align the mirrors and found this to be fairly simple to do just do it in small steps and it was easy
Ok now the software
This is were they let themselves down i think
The manuals that come with it are not very simple and they explain alot of stuff but not always how to get from a to b (just this is a and this is b )
My first big problem was trying to find out were to plug the pc into the machine after a few emails back and forth i found that they didnt put in an extension on the curcuit board to the side of the machine and that i had to plug the usb cable directly into the machine board
So i have done this now and its alive
I swear i saw it move by itself and man was that a relief
Im still fine tuning the software but its engraving glass for me and pictures and all LOL
Shadow
