Hi Jason,
Nothing much you can do if you have already bought the list above unless you can return some of them as suggested. When I started out I became a member here just to learn things. After getting much info, then I took the plunge and started buying the things I need like the X2 and such.
I had a look at the Xylotex for a long time and almost took the plunge on it before realising that should one circuit board blow, you have to change the whole thing. I decided to get a separate driver for that reason. Although a bit more expensive but it has a much better expansion capability. I decided on the Keling KL5056 but Gecko no doubt is a fine product except its abit beyond my price range.
You will want to arm yourself with as much info as you can prior to getting the things you need as this will save you time and money at the end. The DRO is just a classic case of getting something you won't need should you cnc your X2 mill.
Just a list of things you should consider when you do get the part for cnc conversion.
1. Separate stepper drivers.
2. Nema 23 stepper motor 295lb.in for x and Y and 495 lb.in for Z axis.
3. Power supply. 48volts 7A or higher. Voltage gives you speed and Amps gives your torgue. Between 24V PSU and 48V PSU, its alot of difference. PSU voltage rating should be less than the max voltage rating on the driver.
4. Ballscrew setup (if you have the cash as this cost the same or more than an X2) unless you do it yourself.
Anyway, this is what I had learned and done. Others can chime in should my list be off abit. Or add to it for the benefit of Jason.
Alex |
