Im guessing that program will trace the contour of a part, and channel cut through a sheet of material in whatever depth path I choose?
Those channel cuts just keep building up chips in front of the cutter, and requires constant babysitting in my experience to keep it from loading up. Is that what happens to you?
I wouldn't mind writing programs a bit, if I could just program to the LINE in the drawing, instead of having to manually cutter compensate all the time.
Swami |
