Originally Posted by Mariss Freimanis The G540 will come out of fault without motors attached. Do this:
1) Make sure you have your parallel port set to 'EPP' in bios.
2) Make sure you have DISABLE jumpered to GND (term 10 to term 12).
3) Download and install the Mach3 config file 'G540.xml' from www.geckodrive.com.
4) If you don't want Mach3 charge pump, open the G540 and change the black switch position.
You will get the green LED then.
Mariss |
Hi Mariss,
Thanks for looking at this. I have already done all of these things EXCEPT the only setting I have in my bios is 'EPP/ECP'. I would like to use the charge pump but if my PC has a problem then, oh well. I will look for a link on opening the G540 case.
I had to change the ESTOP setting in 540B.xml to 'active low' or Mach3 would not reset.
-James
