Old 10-15-2008, 08:41 AM
greybeard's Avatar
greybeard greybeard is offline
greybeard is on a distinguished road
Hi cely,
Re-reading your original post, I'd like to ask the following -
Originally Posted by cely View Post
I'm not an ME .........
Are you able to drill and tap holes in the "bracket", even if the bracket turns out to be a short tube ?
........I'm able to get near zero backlash by compressing the tapped nylon spacer
Have you considered that two of your spacers, sprung together, might be a simpler solution to cope with both backlash problems and future wear, than one being compressed? (This could be one cut in half, of course, if space is tight.)
.........I'm looking for a very inexpensive way to mount the lead screw nut to the linear slide..........I would appreciate some help with the bracket design.
Can you post a design/photo of your slide to show how much space you've got ?
Regards
John
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
